- 9 May 2009
HI, thanks for getting back to me i forgot to tell you what i am going to use, I am going for a 3900x with a bequiet dark rock pro 4
The NT-H1 suffers from pump-out effect, whats your take on this. Do the other pastes suffer from this or do i not have to worrie about this.
what it seems to boil down to in reviews is best from top to bottom
1. Thermal Grizzly Kryonaut this is not conductive is it ? how long does it last. ?
2. Gelid Solutions GC Extreme this is not conductive is it, never herd of this paste before.
3. NT-H1 or H2
4. MX-4
But it seems from top to bottom there is 2-3 degrees difference which is not a lot of difference. Are they all the same for applying to the CPU as it seems spreading the whole Cpu before putting on the Heatrsink is best bet. still not to sure about Thermal Grizzly Kryonaut as i have herd different things like its easy to put on and otheres have said its to thick and hard to appliy and others like the link i gave you said there was a bad batch and damages the CPU and heatsink finish.
this link which has the problems are the (Distributor) and if they have problems thats not good, has this been fixed by now are all the bad batch gone as it seems in 2019 they still have problems ?
https://forums.overclockers.co.uk/th...sive.18827970/
I dont want to keep redoing the past as i have had mine on my pc for 10 years now
thanks
3. NT-H1 or H2
4. MX-4
thanks
