Caporegime
Christ, 5 fps.
Christ, 5 fps.
Ah that would be useful, does it make the game blurry like when you don't use your monitors native resolution ?
Why the roll eyes?
What would you set this to if you wanted 1080p on a 4k screen? Better still if running at 1440p what did you set yours to? Cheers
in this game it’s 1/2 I think.
other games only let you go to 70% which makes 1080p impossible (and 1440p while we’re at it)
No does not need to be on in windows, the game turns it on. It is broken though, dark and washed out.
Why the discussion of refunding the game? Performance and bugs that bad?
One thing I noticed in the menu that bugged me, under 'special edition' there are two options. 'core stats bonus' and 'cash bonuses & camp upgrade discounts'. Both are set to on by default and I can only seem to turn the first off. I'm happy to have the special edition for any extras, but don't really like extras that just make the game less challenging.
You understand the nature of benchmarks right? The minimum will always be single digits in any benchmark. It's the initial jump into the loaded environment, not during the benchmark running.
Any game with a benchmark functionality has this.
1440p is 2/3rds or .666 can’t remember how it works
No it doesn't, I can fire up Borderlands 3 right now and show that it won't bench in single digits.
But hey, if you want to get all pissy because you think I disrespected your rig then crack on.
I too disabled these, it seems a bit OP to be gaining the extra stuff.
I'm not getting pissy, I've been playing the game without stutters at very good fps with everything ultra lol, I've nothing to prove. I'm just trying to help others understand the expected performance from a specific setup for those who might have the same setup as it's a common mish mash of PC components.
And sure, load up Borderlands, I'm almost certain it will have the same. I'll do the same as I've also got BL3 installed.
