Red Dead Redemption 2
Finally got it to work, rolled back a BIOS update, was on 42d rolled back to 40
I won't be doing that, think that's the bios that Destiny 2 doesn't start with and I play a lot of that. So by the looks I have to wait for a bios update. Did roll back to 42a but still got the launcher crash.
I'm really not sure why a lot of people are having issues and I hope they are solved soon for you guys. Once you get stuck in, it's a truly brilliant game! And bloody gorgeous.
Here are my benchmark results and settings. My rig:
Asus ROG PG279Q 1440p 144hz IPS (gsync enabled)
i7 8700k @ 4.8Ghz (all cores) - Kraken X62 and it's delid
32gb Corsair Vengeance Pro 3200mhz (XMP ii)
Asus Z390-E
EVGA 2080 ti XC Ultra - OC'd core to 2,100 mhz, memory at 8,000 mhz
Asus Zonar STX ii Sound Card
1TB Samsung 970 Evo m.2 SSD (I've other normal SSD's, no mechanicals, but the game is installed on the m.2)
Here are my options and results:
Nice lol, did you not fancy dropping some settings and using MSAA? Its so much better looking than TAA which is very blurry IMO
I just messed with the res scaling at 1080p, to get rid of blur I had to set it to 5/4 x1.250. I don't even know what that means.
That res scale option is a god send, 1080p 5/4 1.250. Has let me put settings on high and ultra and medium and a couple on low. 60 fps but my gpu is 99% used all the time.
Mate lol, think of your native res as 100% or in this case, x1.
Setting x1.25 means you are running a resolution 0.25 higher than your max res, so you will be losing a bit of performance by upscaling but it will look nice for sure hence why the blur has gone.
What are the thoughts of those playing RDR2 for the first time? (Technical issues aside.)
I've only had time to play chapter 1 so far, but I've really enjoyed it. Looking forward to having a bit more freedom from now onwards though. I can see why people suggest keeping a save at the start of chapter 2.
After the 2 hour prologue which I felt was quite restricting and being out in to the open world it feels like a much improved and built on GTA world. I never expected it to feel so alive but casually riding through the landscape leads to all sorts of unpredictable scenarios. It almost feels like the world responds to how you behave like you would expect it to in real life. I fired some shots nearby a fort in the wilderness and after a couple of minutes a patrol was sent out to investigate, and I wasn't even that close but they still took an interest. I haven't touched the main storyline yet and probably won't for a long while, there's plenty of side quests and areas to explore.
I've not tried to be honest, will check and compare, thanks!
After all my talk of stability and smoothness. I just had my first crash. Hopefully I didn't lose too much progress.
I also found the below:
Alien space **** in the hut with all the dead bodies
Been working perfectly all day for me with not a single issue. Turn the PC off to grab some food, come back an hour later and getting the same error as everyone else now!
