Caporegime
- 22 Oct 2002
- Boston, Lincolnshire
Graph looks excellent. Bet there will not be much that will keep up with that on track!
Hope you've done an underseal recently, one does not simply drive an MX5 in the winter without it rusting by the springFitted a full set of winters to my MX5 NBFL
Hope you've done an underseal recently, one does not simply drive an MX5 in the winter without it rusting by the spring![]()
PornI had a HKS EVC-S boost controller fitted (and some other jobs sorted out):
Oil and filter change on the Sportage.
used my new tool which sucks the oil out of the dip stick, meaning I don’t have to get underneath and find the access hatch in the under tray.
it worked way better than I expected. Much much easier. Got all 5.5L out.
Not bad for £40
does this tool exist for all cars? That sounds awesome!?!?! where from?Used to use it for my old focus and I believe it's universal. You pump it up and create a vacuum, leave the tube in and let it suck the oil out slowly. You'd need to pump it up Every now and then.does this tool exist for all cars? That sounds awesome!?!?! where from?
Had I known about these, clearly been around for years, I could have done my own oil changes. Oh the shame !!
Im going to explode soon I swear to God... The middle pin on the alternator loom connector doesnt have continuity to ground and doesnt have any voltage output when ignition is on.
I think it is meant to go to a 7.5A fuse... Nobody on the Owners Facebook pages are replying to my post, and I can't find the location of the fuse or the fuse box it is in online, and I can't even find any confirmation that the pin is supposed to have continuity to ground or a voltage output, but the alternator company say it should.
