Post Your Home Cine & HiFi Kit...
12 Jul 2007
South East
Wouldn't you be better with a wider separation of the left and right speakers and angling them toward the listening position? That's how I have mine set up after reading about it on AV Forums. Although I must admit my setup would look nicer if I were to put them like yours are.
No, you want to form an equilateral triangle with the distance between the speakers and the listening position ideally.
3 Nov 2003
Lancashire
I've got Monitor Audio Golds and I've never been 100% happy with the sound, perhaps it's my amp but I may try less toe and see if it helps.
What amp you running with them?
I used to have a pair of GS10s and they sound amazing with a decent amp. They do need a bit of grunt though. I had a Roksan Kandy Liii at the time. When I ditched that to go av they sounded pretty average. Tried Yamaha , Dennon, Onkyo then finally a Arcam av amp. None got them to sing like the Roksan
Man of Honour
20 Sep 2006
I’ve got a Roksan K3.
Man of Honour
20 Sep 2006
Take it there on decent stands and have room to breath.
That combo should be a great match.
I’ve tried all sorts and been disappointed. I may borrow a CD player from a mate to rule out the source being the issue (Sonos Connect and flac files).
3 Nov 2003
Lancashire
I would. Something ain’t right there. I know audio is subjective.....
if you try that and your not happy I guess it’s time to find a nice local hi fi dealer. One that will let you take your stuff in and swap components in and out.
Man of Honour
20 Sep 2006
Sevenoaks are just down the road, the problem is my speakers aren't exactly mobile, I'm not sure I'd be able to fit them in the car.
Man of Honour
20 Sep 2006
It's a large and mostly squarish room, it's a new build so plasterboard all around. It also has laminate flooring. I'm tempted to get a Roksan CD player as I have a load of CDs and I enjoy albums from start to finish, it could then double up as a DAC for the Sonos if I connect it via digital. It may improve the streaming plus I'm going to get the best input from a CD. I don't fancy paying full price though and the cheapest ex demo I can find is still nearly £1000. Other colours which don't match my amp are available cheaper annoyingly. I will just keep an eye out.
12 Jul 2007
South East
I doubt doing this will make a lot of difference unless the Sonos is doing something particularly aggressive (DSP / upsampling) to the output.
What don't you like about their sound?
If the room has bugger all in the way of soft furnishings then you're not going to enjoy a particularly great soundstage.
12 Jul 2007
South East
Wow, @Unomelodica, that looks stunning. Very classy. Well done.
I've made a few changes to my little hideaway since I last posted some pics, namely room treatment in the form of broadband acoustic absorbers from www.bluefrogaudio.co.uk (wow, what a difference!), wall-mounting the rear speakers (@agw_01 initially suggested this, and it has made an excellent improvement to the rear soundstage), and some of the new Philips Hue Richer Colours GU10s in the ceiling. At the beginning I told myself I don't need coloured lights overhead. I decided that I was wrong. And I love it. The lights can be a "normal" or as cinematic as I feel.
