That end wall is begging for a projector screen
Lookin good, blue looks smart
That looks great - I love that deep blue colour.
Can I make one suggestion/criticism?
It's a very simple one. The Fallout artworks....I'd move them down a bit. They look like they are hanging very high on that wall, and it looks a bit unnatural, and makes the ceiling look lower than it is. They also seem a bit close to the wall on the right hand side.
I'd move them down a tad and also group them closer in two rows (like how they are laid out in the first post) and I think that would look better.
Yep should never hang anything that high up on the wall.
I agree I think the 2 rows like in your mock layout, centrally above the desk could work.
New ornament for my setup to go alongside the PCB's and other cpu's etc I plan on displaying (This is a working chip I was given)...
So that means I should now have the whole range to display, a ryzen, a TR and also now an EPYC... question... anybody know anybody or where I might be able to either get some stands 3d printed or perhaps made out or plexi or something?
It might be best to draw some designs up of what you are thinking.
I'd probably look at some box picture frames, mount some cork in there to push the pins in to hold it steady then you can surround the CPU with coloured card or a design of some kind.
Something like this surely![]()
Looking slick in there. Definitely giving off man cave vibes.
Possible suggestion: flip the door around so it opens the other way and then get a bit of worktop to make a desk the full width of the room?
Not a bad idea that. that desk does pretty much fit the full width but I'm not a fan of having it along that back wall. My old desk was there for ages and it wasn't giving me good time vibes.
I did something similar with an ikea worktop and it looks pretty slick and it's solid. Plus you can fix it at a height you want rather than being dictated by desk manufacturers!
is it exclusively blue ? or ambilight ... doesn't that impact your sleep, or thats the 24/7 life of a gamer
personally even experimented with lower blue/green oriented dektops, and 'blue' glasses
... nice desk - good depth.
I like it and the new arrangements for the Fallout pictures are very nice, looks a lot better how it is now. Nice choice on desk, i remember looking for ages to find a good sized one in the stlye i wanted for a reasonable price, mine is also 1800mm wide and i got a matching desk high pedestal to put the tower on next to it. The extra space, once you have it, you can never go back!
Also a lot of desks i see sold are not very deep, that looks 80cm deep, is it?
