This means that Ampere will be later, AMD's share price also hints it.
Ampere being late was mentioned weeks ago
Potentially this would mean +15-20% performance vs reference 2080ti @ 4K. 704-768 GB/s.
Not too bad. At least until we hear the price.![]()
This is nvidia we're talking about. They may try it on at £1.5k+ and see if they sell. And if they do, the price won't move for months.I'd say 2080ti will be nudged down in price a little bit and this will take it's place at the top price.
Not a change, more like 5% or 6%.
RTX Titan has Samsung memory that has no problem if you clock it to 4000mhz. Even using the full TU102 chip the Titan is only about 7% faster than a 2080 Ti.
Is that clock for clock?
It's going to be £1700 minimum but probably nearer £2000+.Given the pricing of a 2080ti and the limits of the technology and core count, what’s the bet this, if it does arrive, will be 400MHz on the core, maybe a couple of Gigs of extra ram and another few hundred Hertz on the memory? And an extra £200 for the privilege?
Too many people bought into the ludicrous 2080ti pricing for Nvidia to row back on pricing. They're
a very greedy company.
My 2080 Ti FE came with Samsung memory that easily clocks to 4000MHz so I'm not in any rush to sell it and put another few hundred on top for a SUPER which will give maybe a 7% performance gain followed by Ampere coming out 6 months later, At that point it's just wasting money for the sake of wasting money.
Forget any quoted clock speeds from NVidia about the 2080 Ti and RTX Titan.
The important one is under identical conditions both cards boost and run at the same clockspeeds (allowing for the silicon lottery).
Extra memory chip to bring the total up to 12gb - very little cost there.
But that's what I'm asking, since you had (have?) both, if the performance difference owing to the extra cores is 6-7% at the same clocks.
That's not quite correct, because in order to have 12gb it would require larger bus width, which costs quite a bit more. And the extra cost of redesigning the PCB in order to be able to use 16 Gbps memory is also there (hence they didn't use the full 16 Gbps for 80 Super). So while it may not be much of a problem for Nvidia, it's questionable if the aibs will tank their own margins just to sell the consumers a faster card (compared to just selling 80tis). I don't see how they won't increase the price vs 80ti.
