Hi guys,
Looking to build a machine that I can use to edit my massive collection of old videos (mostly HD at most, but a few are higher quality). I've spent almost two weeks trying to decide on the parts, and the list below is the best I can come up with given my extremely limited knowledge.
I would like the machine to have no issues playing two 4k vids simultaneously, even better if it can play three. Main use will be movie editing. I have tons of old videos (1080p or less) that I need to trim. Occasionally I may need to dynamically rotate vids (due to phone being held at random angles through the entire vid), or stick a few cropped videos side by side, but thats about it. No effects or colour correction or any of that fancy stuff. I may have to work with higher quality source like 4k or above thanks to all the new phones me and my family use, but just to do the operations/edits mentioned above.
Now my current 8 year old PC can almost manage the tasks I'm talking about. So why the hell do I want such an over the top spec? Simple - I need to do these things quickly, mainly the final render. So a hefty example in my case would be something like - three 1080p vids from my phone. I want to create one video with all three playing side by side with each of the vids cropped or rotated throughout the timeline. The editing process in Premiere Pro on my current machine will take me around 25-30 minutes (lets say each vid is about 10 minutes, with almost 7 minutes trimmed away) if my final video is going to be about 5 minutes long. Rendering the finished video will take more than an hour on my current machine. If I was working with two instead of three vids, the render will take about an hour. For trimming a single 4k video, it will take around half an hour.
There isn't too much I can do about the time I spend editing. Yes a faster machine will help me see the results of my edits quicker so maybe I can cut a few minutes off my editing sessions, but the rendering of the final video is what kills it for me and is pretty much why I haven't bothered anymore. If I can get a new rig which will render a 1080p 5 minute video in a minute or so instead of half an hour, then I will be getting back to work on all the old footage.
I'm thinking of using Da Vince Resolve as its free - but does that mean forking out more on a graphics card? Would I be better off buying software like PowerDirector and getting a cheaper GPU? Perhaps its more related to the actual work I want to do so what do you think based on the scenarios I explained above?
Here's a list of parts that I've come up with. Started off with youtube and amazon recommendations and refined based on some of the things I've read on this site after searching for threads related to video editing and/or Ryzen builds. PLEASE ADVISE on these and what I should change. Once it looks like people approve of the build, I'll go ahead and buy the parts. The prices listed are all from amazon, but once I've finalised the parts list, I'll be shopping around for the best prices.
For the OS, I'm going to try and install Win10 pro myself. From what I've read, I need to create a usb boot disk, buy the key off ebay or something and then hopefully the rest will be smooth sailing right?
So based on the needs I mentioned, will a ryzen 7 3700X render my videos much faster than a 2700X? If yes, I don't mind forking out the extra £150 or so. Heck, if it renders faster, I don't mind getting a 3900X.
Many thanks in advance
-Naz
- CPU - Still not sure. 2700X vs 3700X vs 3900X?
Motherboard - The most confusing part for me to find out about. Here's a few I've looked at but by no means do I have a preference. I just hope it can take full advantage of the CPU/RAM/GPU. Two M2 drive slots would be nice, but not necessary. USB-C would also be nice as it sounds like many peripherals tend to use it yet most of the motherboards I checked don't seem to have it?- MSI B450 Tomahawk MAX ~ £85
MSI B450 GAMING PRO CARBON AC ~ £120
MSI B450-A Pro Max ~ £60
Aorus X570 AORUS Elite ~ £191
ASUS TUF X570-Plus - £180
Gigabyte B450M DS3H - £60
RAM - Corsair CMK16GX4M2B3200C16 Vengeance LPX 16 GB (2 x 8 GB) DDR4 3200 MHz C16 XMP 2.0 ~ £70. Haven't gone 32 GB since I'm not editing large 4k videos (yet). Is 3200 MHz good enough or is it worth getting something faster?
Graphics - as mentioned earlier, I'm really not sure what to do here. Buy some editing software and use a cheap GPU, or use Da Vinci Resolve and use a more expensive card? Then there's the issue of me possibly not having monitors that do more than 1080p (not forever as I will get new monitors, just not now). I'm currently running an Asus VE278H which is 1080p and an old Toshiba TV which does HD, but a friend MAY end up giving me two 4k displays. In case he doesn't, it may be awhile before I buy any 4k monitors. After searching this site and reading a couple of threads, it appears that sticking with my 1080 monitors can affect the parts I decide to go with? In addition to movie editing, I want to be able to play two or three 4k videos simultaneously on my non 4k displays, as well as on better displays in the future. Again, no gaming, just high quality movies or videos that I create. The few graphics cards I was recommended from youtube are listed below but I can't tell whats good or bad and how suited for my needs they will be.- ASUS Dual GeForce RTX 2060 SUPER EVO OC edition 8GB GDDR6 ~ £410
MSI RADEON RX 580 ARMOR 8G OC Graphics Card '8GB GDDR5, 1366Hz ~ £170
XFX Radeon RX 570 RS XXX Edition 1286MHz, 8gb GDDR5 ~ £127
ASUS GPU Nvidia GTX1650 Dual OC 4G Fan ~ £156
PSU - Anything that is Gold standard and gives out 650 Watts or more is good right? - MSI B450 Tomahawk MAX ~ £85
-Naz
but I definitely want to get as much bang for my buck as possible. Hence the indecision between 3700x and 3900x.
