- 30 Jul 2013
Thinking on solutions to this.
Could I not install a cheap Nvidia GPU and use the HDMI on that for audio?
Pretty sure my LG c9 has raw and pcm setting on digital out
Ah brilliant
I set my TV audio to 'Auto' and turned on eARC (not that my avr supports it) and now my AVR says DD+
And it seems to be in 5.1 again.
That's better than stereo at least.
This thread is a goldmine!!
I have the same AV, and am very close to getting the B9, was wondering about this very issue, and it's all documented here!
Just to make suer I understand correctly... If I plug the GPU directly into the TV (obviously) then VRR will work fine, ARC the TV into the AV (obviously), and set the TV audio to auto, while setting the AV to TV, this should deliver Dolby Digital + in 5.1... right??
Its a little older Marantz NR1504What AVR do you have @MassiveJim
I should mention that I still had to set my Windows 10 to 'Dolby Atmos' (I already had the app) and that's when the receiver picked it up and showed the 'Dolby Digital' logo and then also D+
Either setting the TV HDMI sound to auto or enabling eARC seemed to make the bitstream work better.
Can't you use ARC ?Damnit optical out is blocked even with a 90 degree adaptor. So for dvd and Android box can't route audio out of tv
Does such a thing exist that would split the sound from HDMI and send it down a separate HDMI cable
Have not done this in practise but my understanding - you can get a £25 4k splitter/stripper that will send required 4K/10bit EDID&handskake to the shield (or other hdcp2.2 10bit/4K source), and splitter strips the hdcp at the output, so you can then send it to both tv(hdmi2.0/hdcp2.2) and AV amp(hdmi 1.4/hdcp2.0)
The AVamp will ignore the hdr metadata which is in the video stream;
of course, will need to ensure you send an audio stream from shield that works with av
The solution appears to be a passive adaptor. More here:Same as you.
I'm going to hazard a guess that Nvidia will only output the full range of audio options via HDMI.
I notice ASUS do a Strix 2080Ti with 2x HDMI ports - Obviously i'm not going to go to those sorts of lengths to get decent audio back, but maybe somebody who has one can confirm that both HDMI outputs offer the full range of audio options?
https://www.avsforum.com/forum/26-h...o-receiver-through-dp-hdmi-adapter-cable.html
AFAIK Nvidia cards allow you to have video going over one HDMI out and audio output to another HDMI connector (a D++ port with a passive adapter is considered essentially the same thing as an HDMI port), so it should be doable.
UPDATE
It only flippin' worked!
Bought a basic 'Display port to HDMI' cable, plugged it in to the spare Display Port output and voila - All the multi-channel surround options:
And thanks to a certain generous rain-forest return policy, I can get back the the money I spent on a MSI NVIDIA GEFORCE GTX 1030 and my 2080Ti is back to 3.0x16 mode![]()
