1.4 turbo suzuki vitara.
Swift reviews better in every way.
What? It's a different type of car entirely, how can that be the case?
It also has 4wd, and the op wanted a crossover.
The OP is wrong because Dis86 doesn't like crossovers/SUVs thoughthe op wanted a crossover.
4wd isn't standard and is also available on the swift soooo...what's your point?
And as I pointed out, I want a trashy blonde but there are better options out there.
Lol no, the 1.4 turbo does not come with 4wd on the swift. The 1.4 vitara sport has 4wd as standard.
How's it a different type of car entirely? They literally use the same engines, suspension, interior components. The vitara has something like 10mm more ground clearance and is about a foot longer. It's a slightly bigger hatchback than the Swift.
The Swift is a small hatchback and the Vitara is a small SUV.
I appreciate you are dead against people buying cars they don't need, though. Which is why I am sure you've never owned a 5 metre long twin turbo 3 litre 6 series or a 2 seater Porsche![]()
The 6 series was perfect for the long distance driving I was doing at the time
A high spec 520d would have been even more perfect. And you don't race so why do you need a fast Porsche?
It's almost like we pick cars based on more than just pure utility versus efficiency isn't it...
sadly I required power for overtaking which just isn't there in a 4cyl
No you didn't.
You might have wanted it, but you didn't require it. Just like very few people require an SUV, but want one...
Sadly, no. Given where I live we have a lot of country roads with short stretches available for overtaking. Often having to overtake dawdling morons in SUVs who can't handle corners at speed as it happens.
