You could always sell your 3600 next year when the 4000 series chips come out and upgrade to an 8 core then.
Just need to be mindful that the 4000 might not be be on AM4
If it isn't there are still plenty upgrade options on this gen.
, plus the question around DDR5AMD would have to take insane risk to bring AM5 next year, because JEDEC's DDR5 specifying process is proceeding at speed of Intel's 10nm manufacturing node.Just need to be mindful that the 4000 might not be be on AM4
I ended up grabbing a 3600x as it was a good deal. Really happy with it so far.
Havnt had a amd cpu since a socket 754? 3700 15 years ago.
YepThe right choice![]()
, will upgrade to 8+ cores when they are needed and cheaper.
Good choice. As humbug said, the right oneYep, will upgrade to 8+ cores when they are needed and cheaper.
All without changing my motherboard too........what a time to be alive![]()
doing the same choice from a i5 6600k, im guessing the 3600 will totally destroy my i5 for gaming?
got a radeon 5700 pulse recently and the i5 is showing signs on some games of starting to be a bottlekneck as i only game at 1080p.
