*** The Official OCUK Cinebench R20 benchmark Thread ***
Bit of a lame attempt on my 3970X - only boosting to 4.05GHz with my AIO barely keeping up :p:
Jeezuss ####'### hell! :eek:
I'll update later....
Juzuss ####'### hell! :eek:
Imagine what score he will get if he can get a decent overclock? :eek::D
AMD killing it. Which is very nice to see as my first cpu was an AMD one and I was AMD only until core2duo came about.
My first pc was also AMD, can't remember the exact model but an athlon , anyway I remember I had problems with bsod so I decided to take everything apart and put back together ( note I never built or had any idea how to ) basically I pulled out the cpu without opening the socket and put it back and bent a lot of pins and broke 2 :D , I got it repaired and it worked some 2 more years and then it died
Lol. I never damaged any cpu or gpu but I did **** up a psu which went bang due to over tightening the mobo and bending it. I learned my lesson once PC World charged us £100 to tell us the reason another pc I had issues with was not working properly. That was about 20 years ago.
The 64 core EPYC scored 21K @ 2.25Ghz, so if the 3990WX is running at 3.2Ghz it will crack 30K, or cause Cinebench to #### its self.
All updated.
Congratz to g0th2000 for breaking the 17.5K Honorable Mentions score with 17824 points. You now top that spoiler :)
All updated.
You messed up the ST scoreboard again. Time for Kaapstad to take over me thinks...
:p
