- 27 Aug 2003
- West Midlands
To be fair I normally happily sit around the 70-75mph mark anyway. Never been one to cruise at speed on the motorway.
Why thank you![]()
I don't get it. You want to not use your fast, good handling car for work duties and intend instead to use a slow good handling car for work duties. Why not just get something nice, comfortable and economic to go alongside the fun?
Why thank you![]()
If you a vampire drain you'll have to sort that.
But first I'd check is battery health, and alternator health. If they are not 100% it won't retain charge for long when idle, especially in the cold.
We went through a phases of only driving at the weekends and lots of jump starts as a result. Especially in winter. Replaced the batteries with upgraded units, serviced alternator etc. Solved it for us.
Considering parking fees etc, would it not easier to get a taxi or someone to drive you.
Best getting a jump pack for the car. I've got a monitor on my 4th battery and after the initial voltage drop off when stopping it just keeps going at a steady rate. I used to plug it in to charge when at my old place but now rely on a jump pack if I've not used it for 3 weeks or if I've left a light on.
Edit: since getting a ctek charger and using that a few times overnight the drop on my battery has improved according to my battery monitor which is on the car 24/7. Only used the jump pack when I left inside light on for 3 days.
Keyless entry I think. Some other keyless cars do it too, but the gt86 comes with a small battery as standard. The car is constantly looking for the key which is a constant drain :/
Could somebody find me some info on the battery draining problem?
Just spent 7 days in intensive care and my car wouldn't open or start. Toyota rescue came out within 90mins which was great, but I'm facing a lot of time in hospital this year and cannot risk this happening again.
I don't have the brain power at the moment to find it myself. I just want to call the dealership and get them to sort it, and want to make sure they don't wriggle out.
Thanks!!
Dropped my 13 plate off for the recall, got sent away with this:
Quite like it, reminds me of mine when it was new. Justified some the mods I've done too.
Dealer didn't order the parts for the recall though so getting my car back untouched.
