Caporegime
- 8 Jul 2003
- In a house
LoadsaMoney or Gregster will be along soon to post a WCCFTech link![]()
Then Loads cannot wind up people.![]()
NP dudeYep, the 'consoles often use low settings' threw me, i appologise.
I need them to go 16 GB HBM again.
Agreed, the gaming HBM cards have been a financial success for AMD thus far. They'd be dumb *not* to!!
/s
VRS - good, only "some" RT sounds concerning, and no mention of more memory bandwidth is disappointing.
Are you serious?They have been. It's important to understand the wider context.
Are you serious?
Absolutely.
Absolutely. Have you heard of Apple? What about Cray? Or perhaps Google's more your thing (Stadia).
I was talking gaming, and it's obvious the Stadia thing was just a dumping of Vega stock done at rock-bottom prices to (finally) clear it for a clean slate.
And where do you get the information that the gaming cards were sold for a loss and that they could've done differently?
Samsung is positioning HBM2E for the next-gen datacenter running HPC, AI/ML, and graphics workloads. By using four HBM2E stacks with a processor that has a 4096-bit memory interface, such as a GPU or FPGA, developers can get 64 GB of memory with a 1.64 TB/s peak bandwidth—something especially needed in analytics, AI, and ML.
https://semiengineering.com/hbm2e-the-e-stands-for-evolutionary/With the 1,024-bit data bus, HBM2E runs very wide, but not very fast. Two gigabits of throughput is DDR3 speeds, notes Frank Ferro, senior director of product management at Rambus. “By going wide and slow you keep the power and design complexity down on the ASIC side. Wide and slow means you don’t have to worry about signal integrity. They stack the DRAM in a 3D configuration, so it has a very small footprint,” he said.
For reference Radeon VII/Vega 20 is 381mm so this ought to compete with the 2080ti at the very least.
