If I have to slide and jump down another damn mud slide this game is going out the window......
Are you sure you're playing Uncharted 4?
It's a pretty poorly optimised game though, even on XB1X it can feel uneven and it's not really a looker much of the time.
Are you sure you're playing Uncharted 4?![]()
Tbh it’s very similar just not as good.
Is that good or bad?The ending is omfg...
Is that good or bad?![]()
Urgh - the respawn time is my only real complaint so far!Enjoying this so far.. although I've noticed for some reason, the respawn takes a little time at times?
takes approx 1 full minute every time. And when I took a couple of dozen goes to beat the Oggbo Boggdo, respawn time was the most annoying part!
