OK guys..
Just played some MW there, was a great experience. Good FPS and smooth gameplay.
A few things though..first off in the menus I get a slight flicker on the screen, very slight.
And also when I checked AfterBurner after a little sesh, my GPU seems to be an issue..
GPU temp : 71c
GPU 2 temp : 96c
Mem temp : 84c
VRM temp : 79c
VRM 2 temp : 0c
VRM 3 temp : 0c
Fan speed : 40% max
Can someone please shead some light on this before I play anymore on this card.
Thanks guys!
Don't use MSI AB with 19.12.2/3 isn't supported and creates issues.
Assuming you have the reference model, yes?
For settings, 1980/1046mv 1780 VRAM is what I use on the Anniversary Edition.
However 1800/930-970mv (find which one is stable) and 1800-1820 VRAM and cap the fan speed to 30% is a great point to be.
The GPU would stop throttling, reducing power consumption by 35-40%. If you go to 970mv see if you can hit 1850Mhz also.
