Recommend a 3d modelling program
11 Jun 2003
Hampshire
Long story short most of the hobbies I enjoy I can no longer do, but I'm a chap who likes to keep busy. So I have a super cheap little PC project planned, and I'll need some 3d modelling to do it.
I'm looking for:
  • Free, or under £10 one off
  • Decent library of models
  • Healthy amount of tutorials online
It's also be nice if there was a PC community already behind the software.
My immediate thought was SketchUp, so before I take the plunge with that I thought I'd see if you clever chaps have any alternative suggestions.
Yes. But it's open source and there's an enormous amount of resources online for learning it. Many game and animation studios donate to and use it.
Whilst it sounds excellent, it seems like this would be excessive for modelling a PC build no, especially given the initial difficulty?
The learning curve for Fusion is quite gentle. I'd never touched any 3D modeling software before January last year. Now I'm building some quite complex systems with Fusion and building tool paths for my CNC machine etc.
And yes, they kind of hide that it's free for hobbyists.
I don't know how to use it myself, but I've seen a lot of PC builds modelled in Sketchup.
Thanks mate. I'll see how I get on with both, do a bit of research, and decide how to proceed.
Appreciate the support of the collective, thanks chaps!
3ds Max. You used to be able to get a free copy for non-commercial use. Not sure if that's still the case though.
Blender is obvious choice.
I dunno if it has changed in more recent versions but I found Blender kind of horrid to use (and I've used a lot of 3D modelling packages over the years). Not specific to Blender but I find most 3D design software to be pretty horrendous in implementation either making you go through wizard like steps repetitively even for basic tasks and/or having to go through 2-3 steps of advanced options whether you are trying to do something simple or advanced, etc. often with pertinent settings that control what you are doing hidden away 2-3 steps deep resulting in unexpected limitations/outcomes until you discover them, etc. etc.
Sketchup is reasonably good if you have limited experience and just want to throw around some basic shapes for things like case modding.
