- 24 Sep 2013
- Exmouth, Devon
SoC @1.1v seems to be a must on ASROCK boards. Mine needs it on my Phantom gaming 4. And my RAM needs 1.4v at stock settings 3600 16 16 16 32
same!! my rams 1.4 stock 3200mhz will try soc @1.1 sick of it cold booting to factory defaults.SoC @1.1v seems to be a must on ASROCK boards. Mine needs it on my Phantom gaming 4. And my RAM needs 1.4v at stock settings 3600 16 16 16 32
Well - I got the cold boot issue again last night. I had reverted back to 2.10 when I had issues with later versions before and has been fine since, until last night. Sat there with fans on loud for a bit, rebooted, same again. Got into bios and all options had been reset. Manually set everything back as before and it booted up fine. It's an odd one, don't know what it's started doing it on this bios, unless it's a board fault.
Most on auto with mem on XMP and custom fan profiles.
Have you set it to silent mode in the bios?anyone got a noisey fan? = ( - Any idea on how ASROCK are for RMA's?
Maybe worth checking the fan connector as I've seen people on here mention 1 of the 4 pins were bent thus causing it to run at full belt all the time.Yeah![]()
I didn't have an option in the bios for the SB fan, so I downloaded the ASRock utility and set it in there, works perfectlyYeah![]()
I didn't have an option in the bios for the SB fan, so I downloaded the ASRock utility and set it in there, works perfectly![]()
Under load I think I get about 55-58° but I'm water cooled and I don't have great airflow over the board, what's yours?oh - ill try this - what are your temps btw?
Mine doesn't have it, it lists all the other fan controllers but nothing for SB?It's right down at the bottom of the list in the fan section
I'm looking in the bit where you control the fan curve with the graph etc... Is it somewhere else?
Thanks, I'll have a look tomorrow, can't remember seeing that?H/W monitor >> Fan config.
I'll have a look in a bit for youCan you disable the software and give this a shot space monkey? My board is the Gaming X ( basically the same board)
Hi mate,Can you disable the software and give this a shot space monkey? My board is the Gaming X ( basically the same board)
Thanks a lot space monkey I'm not able to find the software on the website ( found some for a x370 ), yeah the BIOS option is still noisy on full load so good news with the softwareHi mate,
Right, I've disabled the software in windows, so its only the BIOS sorting the SB Fan speed.
It works as described, silent is low rpm, full is loud etc... though I've found with the windows software or the customise option in the BIOS that you can get the fan speed lower than the pre-set Silent option, and of course you can set a fan/temp curve![]()
So when you set the BIOS to silent, it still is loud?Thanks a lot space monkey I'm not able to find the software on the website ( found some for a x370 ), yeah the BIOS option is still noisy on full load so good news with the software
