The reduction in power, with discharge, must be common to other electric vehicles, but can't see other articles, presumably it is to protect the battery life cycles,
since if you look at underlying lithium technology https://batteryuniversity.com/learn/article/discharge_characteristics_li
they can support high current discharge until near exhaustion, with that caveat.
- adjunct to this is extensive use of rapid charge can itself be bad for life time cycles (back on the 800mile daily trips need)
But clearly a private hire will so it sometimes, and when you do need to do it, you can hardly ask your passengers to wait around for hours while you recharge your EV half way down the M1, can you?
