What's a good routine though? There are so many on the internet, I don't really know where to start.![]()
They're all pretty much the same, assuming they're for Strength or Size...
Knee pain is a weird one because a lot of the problems aren't actually associated with the knee itself.
How much unilateral leg work do you do? Have you tried band-resisted work to get glute med going? How flexible are your hip flexor, too?
Generally, go and see a physio, but there are a few bits you can do at home which may help...
How heavy does one need to lift on deadlifts before they need to invest in a weight belt?
Sounds like I'm a long way off then. Was just checking as I don't want to cause my self an injury form not using a belt.
i.e stronger core and you could go a long way before needing a belt. I tend to see people using belts for alsorts these days.. From deadlifts, to stuff like bicep curls.Sounds like I'm a long way off then. Was just checking as I don't want to cause my self an injury form not using a belt.
An incredible session last night, 272kg x6 for a rep PB on deadlift and 100kg x16 bench for an equal PB but I had at least 5 more in the tank. 2020 gonna be a year of gainz.
Once you're out of the noob phase and still wish to train movements with heavy axial (back) loading in the moderate to lower rep ranges. IMO as long as you understand what the belt does/doesn't do and how to use it, then it's a good investment. You don't need one (unless you're a competitive powerlifter in which case you'd just be putting yourself at a disadvantage), but there's no drawback to having one either so it's a good investment for the gym bag.
I'd recommend reading The Belt Bible here by Greg Nuckols which goes over everything someone would want to know. Worth reading the comments too at the bottom.
Nothing wrong with the placebo effect, though. My belt makes me a lot more confident, so I can lift more.
