 - 24 Mar 2019
Did you just strip the pump from an AIO or do you have a source where I can pick the pump up as a stand alone unit?yeah its fine- alphacool units are very easy flowing rads- one of the least restrictive on the market along with lower Fins Per Inch so dont need high powered fans.
Unit is 45mm thick rad in cladding ...
My basket at Overclockers UK:
will be swapping pump in mine from 2600 rpm to 3600rpm unit- will be louder as standard unit - cant hear a thing at 100%!!!
Pump seems very capable, very impressed!
