Yes. It also magnifies hand shake which is why when you go over 12x you really need a tripod. Also the higher the magnification the narrower the field of view becomes.
Do you think the 12x zoom is worth it over the 10x (£10 more) on the Pentax SP 50mm WP?
Pretty much decided on these based on reviews on multiple sites and your help, plus others on here
Thanks
Normally you would want to recline in a deckchair or similar so you can relax, take the weight off, and look UP. 45 or 90 degree astro bins are perfect for a sitting position. Don't underestimate the value of being able to hold your binoculars very steady, you might think you can hold 10x binos well enough but you can't - you'll only see the brighter objects. It's takes time for your eyes to adjust to the view of dim objects and you cannot do that when hand-holding. You need some sort of support.
