These are the ones I got.
https://www.overclockers.co.uk/phanteks-extension-cable-combo-kit-black-grey-cm-02e-pt.html
Thanks, think I'm ready to go now.
TU150 isn't quite an sff case...it's like ~24L volume
haha yeah deffo if you're comparing to a full size atx towerStill a lot smaller than my current case
go proper sff like the dancase or rvz03I'll see how I get on with this setup first.
All my bits arrived today and I've built it and installed Win 10.
Build went very well, very happy with everything. I no longer bash a huge case with my knee.
I didn't need the Phanteks extension cables, everything reached without them.
So far the only thing I changed in the BIOS (after updating) was to set the RAM to 3600. Do I need to change anything else to do with the CPU or am I ok to leave it all at Auto/default settings?
I tweaked the fan profile but it's still a little louder than I would like, I need to work out which fan is causing the noise.
Good stuff. I guess I should have said you don't need the extension cables if you route the cables inside the main chassis instead of going through the top section and round the back section to keep things tidy.
