8pack 3600mhz c16 vs Patriot Viper Steel 4400mhz
crucial ballistix have new 3600 c16 (16-18-18-38) kits now and rgb if your into that for £89 last i looked.
Viper steel 4400Mhz kits are quality rated at 94%
£109 currently which is a pain since i purchased another 16Gb earlier this week at £128.
Ah well sheet happens.
Product review for 4000mhz kit here on OcUK.
Adrian said:
Picked up 2 sets during promotion at a very good price considering it's B-die, using with 3900X and Aorus master motherboard. Using Ryzen DRAM calculator figures it is achieving stable 3600mhz 14-15-14-28-42 at 1.45v with 4 sticks populated.
Buildzoid likes the 4400 kit, he said it's some of the best b-die he has.
I'm ordering this for a family member, how did you get on with 4 dimms what speeds and timings on ryzen
I am running 4 sticks 32GB at 3600 16.16.16.32.48 @1.37 V
GDM on.
In fact now you have reminded me I may well try to improve this with all the spare time in shutdown.
GDM on.
I've impressed with the viper4400
temped to pick up a set of the 4000 to see if there's any difference at all...
here's my rock stable timmings at 1.5v
https://i.imgur.com/9RkPBku.png
https://imgur.com/NvwYyrk
WOW THIS STUFF WIPES THE FLOOR WITH 8PACK RAM LOL, I managed to get 3733@ c14
the below, I didn't play with any of the manual timing stuff all on AUTO except the below timings - ran mem test no errors is good to go?
rams going into family memebers pc though :\ tempted to keep it and order a second set!!
Does your Fabric clock and memory run in synch because auto often lowers it for stability.
Note my NB Frequency shows as 1799.6Mhz same as my Dram frequency.
I also have 32GB of the 4400 stuff running at C14 but at 3600Mhz and my tRc is only 48.
But yes it is good memory.
Yup your North Bridge frequency has stepped down / isn't in sync.
Ah bleh anyone got some settings I could punch in to my x570
No guarantees due to diff boards and chip variation but for 32Gb I am using the below.
First the normal result for 3600 32Gb as a starter but enter it all dont just pick the parts that appeal to you.
https://1drv.ms/u/s!ArMHGD-yylU7gdsI8Dfu6bP66KZrTQ?e=7BuPyJ
If you just want to change the settings you already have I would suggest dont bother do it all or just sit back and relax.
This page shows current timings that I have changed to have it running at C14 with a Membench score of 105.69
https://1drv.ms/u/s!ArMHGD-yylU7gdsJSm2Msp-_-AUnfw?e=eut68r
I have put the Dram volts up to 1.45 and will be lowering if possible in the next few days but 1.45 is acceptable if not.
