- 9 Jun 2011
Hi which is better - I will use for build in my sig
crucial ballistix have new 3600 c16 (16-18-18-38) kits now and rgb if your into that for £89 last i looked.
many thanks - im looking for something thats 3600 cl 16 tight or cl14 @3600mhz - is the kit you meantion b die?
how does this fare on tightening timingsno it's micron e-die.
i cant answer that mate sorry. not tinkered with mine i only set xmp.
no problem - thanks for the replies though - i found a kit of which you meantion for £145 including 3600mhz tempted lol
Adrian said:Picked up 2 sets during promotion at a very good price considering it's B-die, using with 3900X and Aorus master motherboard. Using Ryzen DRAM calculator figures it is achieving stable 3600mhz 14-15-14-28-42 at 1.45v with 4 sticks populated.
Viper steel 4400Mhz kits are quality rated at 94%
£109 currently which is a pain since i purchased another 16Gb earlier this week at £128.
Ah well sheet happens.
I am running 4 sticks 32GB at 3600 16.16.16.32.48 @1.37 V
GDM on.
In fact now you have reminded me I may well try to improve this with all the spare time in shutdown.
I've impressed with the viper4400
temped to pick up a set of the 4000 to see if there's any difference at all...
here's my rock stable timmings at 1.5v
https://i.imgur.com/9RkPBku.png
https://imgur.com/NvwYyrk
Does your Fabric clock and memory run in synch because auto often lowers it for stability.
Note my NB Frequency shows as 1799.6Mhz same as my Dram frequency.
I also have 32GB of the 4400 stuff running at C14 but at 3600Mhz and my tRc is only 48.
But yes it is good memory.
Yup your North Bridge frequency has stepped down / isn't in sync.
