some games stuttering with my 5700 XT
20 Oct 2002
Oxfordshire / Bucks
I need to check out more games
but having recently upgraded my GPU, some games struggle to run
for example,
Doom (2016) runs perfectly fine on Ultra
Watch Dogs 1 stutters on Ultra, and High detail
i noticed that when im browsing the internet on for example my GPU , games or whatever, im seeing a lot of " CPU is bottle necked"
could my CPU be the cause of stutters ?
i5 (skylake) 6600K with Prolimatech Megahalems Black + Arctic F12
5700 XT
16 Gb RAM
500 Gb SSD (NVmE)
27" 1080p 144 HZ monitor (AMD)
for example,
Yes
Some games will bottle neck with that cpu yes especially at 1080p if that is what resolution you play at ? you could try overclocking it as most will do 4.4 / 4.6ghz no problem i had one a few years ago and mine did 4.6 but again it's a lottery.
Or upgrade to a newer Ryzen based system.
Thanks for the help
If I put an old GPU back in, would it help solve the issue? Because if yea, then my new GPU is having an impact on my CPU ?
Try turning off the overlays. That includes the one within the AMD control panel, Windows 10’s in game overlay, steam, etc.
See if that improves things. Might be helpful to post the full spec of your machine.
check how much of the CPU and GPU is being used while playing watch dogs
if your CPU is at 100% all the time then it will be causing stutters
again if your CPU is at 100% you could try turning down some of the more performance hungry settings to take some strain off the CPU
Tried WD again with Task Manager up in front
CPU is only around 70% and the game is stuttering
GPU is no where near 100% either
for example,
i5 (skylake) 6600K
5700 XT
16 Gb RAM
500 Gb SSD
Have you got Instant Replay on and if so what is set as it's buffer, System memory or Disk Storage?
For me Disk Storage causes stutter and when the buffer's my system memory I have to limit the length of time to around 10 minutes, any longer and that causes sutter, I've got 16gb's of storage memory but need more to set it beyond the ten minute limit.
Watch Dogs on Ultra doesn't seem to run great even on a 2080ti when the CPU isn't amazing
You can see it go down to 24fps at one point
Make sure you use SMAA and not TXAA
I have the same cpu and although it does hit 100% in some games overall it performs great with my gpu, I do play at 1440p and 4k though, some games will make it stutter a little though especially if they hit the cpu really hard, modernwarfare is cpu hungry but I can play that smooth as sillk almost maxed @1440p 60fps,
the new battlefield is also cpu hungry but can play that @4k 60fps fine, it does make my cpu hit 100% sometimes though, I cant be bothered to upgrade my motherboard etc etc again though so I will maybe get the skylake i7 at some point if I see it cheap :)
overall im happy with what I have now though and will continue using what I got
Replay is off
Is that in the game or amd software?
I'll give that a try, ty
I've been playing doom all evening, max detail on vulkan, no problems at all
CPU usage is around 40 , goes max 85%
Ensure VRR is enabled within Windos assuming you're using a freesync monitor.
Monitor your CPU/GPU uitilisation and also VRAM/Ram usage.
tried Watch Dogs with :
1080p
60 fps
Medium Detail
Anti L etc OFF
Stutters, but less
GPU and CPU seem to have a high usage (around 80 %)
