I think I've seen the monsters attack each other, unless, of course, that was a scripted moment. Thought I'd seen it during intense battle, though.
Just started this last night on hardest difficulty, had to knock difficulty down a bit after so long I was getting annihilated. Is it me or is the mouse movement a bit weird?
Anyone got any recommended settings? I turned motion blur off straight away. I'm set to Ultra on a 6700k and GTX 1070 @ 1440P (static res scaling) and it runs well (not monitoring frames). I think I might be able to get more out of it. I had crashes when loading at first however changing from fullscreen to borderless window fixed that. Is there a performance hit for doing that?
Is thwere any way to play "normal" mutiplayer?? All I can see is 1 doom marine vs 2 deamons. I just want old school doom multiplayer. many marines in a deathmatch
Just started this, enjoying it so far! What are the best settings to use for 1080ti @ 1440p? Notice some dips down under 60fps at times when it gets busy.
im running a GTX1080 at 1440p and frequently dip under 60fps at "Ultra" settings (no vsync no motion blur). And bear in mind "ultra" settings are essentially medium in this game (there are two further above). I dont think its that well optimised at all. I get double the FPS in Doom 2016 at max settings and both games look pretty much the same to me.honestly, that really surprises me. A 1080ti should run this game way above 60fps at that res, it's incredibly well optimised.
Well I have told you my spec and how it runs. Runs OK if you consider 60FPS at "medium" settings oko_O
Eternal is way more advanced graphically than 2016!
The new engine has been universally praised for its performance and optimisation, it should run like a dream on anything that's not a complete potato. It even runs on a base xbox one lol
GTX1080 and 3700x. Hardly a potato.
Monitor refresh rate? V sync on?Strange. not sure why I am low.
