 - 22 Aug 2005
 - Clydebank
I create a copy of my Photos library onto my NAS (or ext. drive). Surely this is a easiest solution?
It doesn’t solve the problem, no.
Basically you need 1 machine which you can plug an external drive into to be the machine that downloads all of the originals.
As you’ve mentioned this cannot be your current Mac.
To me that seems to suggest you need another Mac designated for this purpose.
I do pretty much the exact thing as you are trying to achieve except my existing Mac is the machine that houses the originals, so I already have somewhere to plug in an external disc and make a copy.
But I really like the idea of having a Mac mini sitting doing this so I can turn on optimise storage on my MBP!
Thanks. Exactly!
my question was is this the only way, and short of going down a vm route (maybe even a vm on my existing windows pc) it appears to be.
Why cant apple just make a time machine option for icloud. I.e->a literal CHECK BOX to download originals to time machine when plugged in. That way i could use my existing backup/ external drive and setup with dock as i do now but still have orig available and optimise on the laptop. Maybe but apple are removing features from their software these days rather than adding so we’ll see.
I’d say for reliability and how important photos usually are, I wouldn’t be relying on a VM for this task, but that’s just me and the level of risk I’d be prepared to take!
I like the idea of time machine backups downloading new photos on the fly to backup the originals whilst still leaving your Mac with optimise storage turned on. Maybe submit feedback to Apple on that?
Photos app should have a 3rd tick box beside the options to 1) Optimise Photo Storage and 2) Download Originals that should read:
3) Optimise Photo storage on this mac and Download Originals to Timemachine
This is because 1) on my Mac Book Pro I have non-expandable internal storage, 2) some people have photo libraries larger than their computer can hold, and 3) Timemachine is the natural place to backup my data, this makes sense.
The MacGeekGab guys are very against saving the photos library on an external drive, saying that it's known to cause big corruption issues. I've never tried it so I can't comment but they're always very vocal against it whenever it's mentioned.
In the VM you store the Photos on an external drive then, not 'within' the VM. Sorted.
No, for the main location of your Photo library file.For backups....?
You might not be able to find an elegant solution which solves all of your points.
How about buying some onedrive storage and have the iphone sync the camera roll to both photos and onedrive? AFAIK, onedrive (unlike amazon photos) uploads the exact 100% raw image in the apple format (not jpg). That would do for your backups and wouldn't eat up your local storage.
You could also install the onedrive client on the mac to see them in finder.
Plus, if you fancy an office365 family sub, you get 1tb stoage with vault access and can share the plan (or sell wink wink) to 5 friends.
AFAIK OneDrive STILL doesn’t support Live Photo’s.
