Is it just 5 bolt 110bcd?
Should be plenty out there. 10/11 speed chainrings all play together.
Yes, 110BCD 5 bolt - will probably go for the 5750 from Wiggle as they should deliver quickly
https://www.bike24.com/p2183552.html
The wheels will come with wee plug things that insert into the bigger holes that your canyon will use. You can reuse the skewers from the boardman.
There is about 4 different bags with bits and bobs for qr, 12 and 15mm axle parts. Pretty much they will come set up to go straight on the canyon and you add the plugs, I think removing something off the back wheel as they are 142x12 and need to be narrower for the boardman. Read the instructions it does make sense or post up photos as the lock nut on the drive side is left hand thread I'm sure.
I'm disappointed if I don't hit 50ft/mile, since I've moved I'm definitely getting more hills in, been out on the cx bike and usually hitting 100ft/mile. I've got no choice if I want the quieter roads. But that's what I prefer, much better now I can take descents at slightly higher speed,although so many high hedgerows round here you're always tempering it slightly, and still loads of gravel washed down on the roads from the winter we've had that'll take even longer for the cars to sweep away with current traffic levels.That’s a lot of climbing! In metric I aim for 100m every 10km.
Gotta make sure you eat something going past 2.5 hrs esp if you’re doing efforts, was a headwind for me Sunday coming home, luckily I took the lanes and dodged riding into it constantly.
you want to use the bike in trainers
Remove the plastic special ring though lol
Why not?Why have those sort of pedals on a bike like that? (just curious!)
Why not?
Chop it offN00b question incoming, do I have to take the cassette off to do this, or am I missing something obvious for an easy way to just remove it?
