- 9 Dec 2015
Hello,
After a headset currently using HD681's plus a 6 quid mod mic, wanting to upgrade to an all in one as the clips all broken and using pegs on my shirt and i'm sure it sounds pants, thought about getting a proper modmic for these headphones but they are literally the price of headsets and I dont want two wires really.
So after something with an easily accessable mute option, equivalent or better sound than my current headphones and what about surround? im confused, I basically want the optimum setup for FPS, locating sounds etc. Do I need surround sound, looking at the Logitech Gaming Pro X but it says for surround I need external soundcard and to use USB instead of 3.5mm? is surround essential for locating foot steps accurately? will they be much better than windows sonic, also I want to keep software to a minimum. Any recommendations, wired only.
£100 budget or less, not that anal about sound as half deaf with tinitus anyway but want it as good as current headphones.
Thank you
Thank you
