- 14 Jul 2005
- Bristol
There are a couple of mods to that grinder which give it much more consistent grind size. I have two grinders - electric burr grinder set up for machine espresso, and that Hario for French press. I don't mind the manual grind on a slow Sunday afternoon when making a whole pot
I also appreciate not having to change settings on anything!
This seems entirely pointless using the Hario for French press given it's pretty naff for making coffee and the whole point of the Hario is to get a good, consistent grind for something like actual filter V60, Aeropress. I can only assume the beans you use are fairly generic and you don't mind over extraction and bitter coffee...which begs the question why you'd use whole beans in the French press in the first place. Also modding it when you're using it for French press seems again, largely pointless.
My Hario mini mill is broken from loads of use and I bought it when they weren't stupidly costly. I replaced it with the De'Longhi KG79 but I'm finding it extremely messy and not actually all that consistent or precise. I'm always adjusting my grind though because I use a mix of V60, Aeropress and CleverDripper along with always changing beans week-on-week so dialling in each bean for maximum flavours takes a bit of work and I'm not sure the KG79 is quite up to the precise grind I'm wanting.
It's so messy which really is a massive downfall of it. It's got loads of security features to stop you grinding your fingers but it just doesn't contain the grind well enough when moving grind into the basket, fine grind ends up being thrown around on the worktop.
The grinder I now want is £100 or so, more grind control and much less messy as I recall from seeing it in action at a coffee event.
I do have some other kit arriving today though
from the other half...but that's why I got the separate grinder for filter, so no need to for messing about with the grind. Only complain with the Eureka is that it needs more than a full revolution to go from espresso to filter grinds, and you can't tell which turn you're on.
