Really no sense in overclocking Ryzen for gaming.
Outside lower core count models it would be hard to push all core clock high enough to not take hit in signle core from automatic boost clocks.
While it's possible to disable cores to get higher overclockability for enabled cores, that's tedious operation and would fast limit performance in multithreaded games.What about OC'ing for single core if you mostly play just one game that doesn't make much use of multi-core, will that give any advantage over automatic boost clocks? I was thinking about getting a 3600 and overclocking rather than say just getting a 3600X and running it stock.
Should I wait for X570 Tomahawk or any other suggestion?
Besides if cooler is properly sized Ryzen's automatic boosting pushes cores pretty high for silicon's capabilities.
Cheaper combination of 3600 and separate cooler likely performs better than more expensive 3600X with its chronically undersized stock cooler.
(and 3600X with separate cooler just becomes too expensive for low end less than next-gen consoles core count)
That cooler definitely enough for six cores.Interesting. In my situation I already have a decent (I think?) tower cooler, the Gammacool Deepmaxx 400, so I'm wondering whether that makes the 3600X the better buy for me, for only an extra £30. Or whether when overclocked, both will end up about the same performance so not worth the extra £30 for the X.
Reviewers actually haven't touched 3600X much, but performance has been inside percent or two of 3600 in best cases.
And for lowly six cores MSI B450 Tomahawk is well enough.
just watched this, and there's no where that has them, no where seems to even show them on their websites for pre-order or just info.
I fear that this board is not coming to the UK soon since it's not even listed on the UK version of MSI's site![]()
FWIR and heard, it's not out until early May, are you waiting? I really want it for my full system build but that means waiting for a few weeks and i'm going stir crazy indoors.
I really want USB-C ports on the rear pane
i understand the wifi requirement, but what about the usbc port?
