I know it's not what you wrote but it was directly implied by what you wrote, hence me pointing out what you were effectively saying (to highlight the silliness of it).No, because that's not what I said at all.
So if I'm following all this right, you're argument is that petrol sold at chain/franchised petrol stations (BP/ESSO/Texaco/Shell/etc) is good because it it will meet and most likely surpass the EN228 standards (albeit we have no way of knowing how much by), but petrol from supermarkets and independent petrol stations is not as good because it will also meet and most likely surpass the EN228 standards, but you say the magic juice in yours is better.All meet the UK fuel spec of EN590 or EN228 so you are right if I have incorrectly made out they are all bad. And compared to other parts of the work the UK fuel is very good.
The design of the engine itself is a much bigger cause. If oil consumption is high then it's likely there will be bad buildup as well.
Is this just an issue with petrol? I’ve had three brand new cars in a row, all diesel, all gone back at four years old with roughly 125k on the clock and I’ve always used supermarket fuel and never had a fuel related issue. Is there less of a difference between premium diesel and supermarket stuff?
All the fuel is the same, it all comes from the same refineries the only difference is any additives. All fuel in the UK has to meet strict standards anyway, this idea there is a vast difference between them all is laughable.
Sure. What makes you think the UK standards are 'strict'? What requirement exactly? I'd be interested to know your views being as hundreds of people work to develop fuel around the world.
All food meets the same standards, you telling me it all tastes the same?So all the fuel in the UK is of the same standard, it all comes from the same refineries and the only difference is the additives. So your argument is what exactly?
Of course the additives in the UK are different, they make all the difference. Try using fuel without additives if you think they make no difference.
Makes zero difference really. Shell and Exxon i would advocate the same benefits.I've just seen you work for BP? Not quite independent in this then.
All chicken tastes like chicken.
I've never seen an engine killed by using supermarket fuel either.
Don't confuses your opinion with fact mate.
