I used to keep red bellied piranhas and the dream was an indoor pond for them. Like some kind of Bond villain.![]()
Or electric eels.
You'll need at least a 1000W heater as well, probably a lot more to keep the temp steady :O
The US has some great acrylic sumps. Before I settled on the DD reef pro, I was looking at doing a custom tank with acrylic sump. Must have emailed about 4 companies, and none of them had a UK outlet.
I have 2 600W Titantium ones on my tank with a Inkbird controller. Does the trick perfectI always use 2 heaters in sump incase of one fails so 2x300W should do![]()
Yeah i got 2 Aqua medic ones.I think I'm going to go with 2x600w now, shego for the win.
hooked upto my Inkbird. them work well keep me 7x3x2ft & sump at a constant 27c
Going to start stock piling gear for new tank this year to ease the coinage burden in one go![]()
The problem with buying stuff way in advance is that new gens of stuff come out. By the time they built my tank the newer ai's came out, and I ended up changing the order as it didn't feel right not having the latest ones.![]()
Heh, need 1 more gen 5 won't be changing that for a while so that's safe, bigger nyos skimmer, I'm more excited about having a refugium with lots of copepods in.
.This is what I need, more life. Because I went down the real reef rock route, the tank is lacking a lot of the good stuff.
Start dosing phyto if you aren't already. I decided I wanted to give a mandarin a try so started dosing the Reefphyto super concentrated stuff about 6 months prior to getting one. My tank was and still is absolutely crawling to the extent that I don't even really need to harvest from my pod cultures. Of course the little bugger then decided he was perfectly ok eating frozen, pellet and flake alongside pods. If your tank doesn't have any micro fauna then try and get hold of a piece of real live rock as well. I heard white corals have some good stuff at the moment and are still shipping.
Thanks, good post! I was in the process of adding copedpods from a couple of cultures I'd set up, when the tank crashed in December. Too much too soon.
I'm now coming out of that and have been slowly getting the beneficial stuff from the corals I've been adding. And I'll be getting some cheato that's teeming with life.
How did the tank crash, i lost my nano through a crash, i put it down to small tank and not enough care as i was working away a lot, closed it down now and just big tanks for me for now on due to my work load.
. I got to be honest it was neglect on my part for not doing frequent water changes and big mistake cleaning the filter using tap water on 2 successive weeks which most likely killed all the good bacteria.
The short version is..
The real reef rock didn't have enough bioload to cope with the fish. Disease took out a yellow tang, Lamarck's Angel, 2 clownfish and a male Lyretail & harem. It was a bloodbath.
