How are the temperatures with the glass front?
What components do you have in there? MATX board?
Seems like there is some rattle coming from both the 200mm fans. But one is worse than the other. This is mainly detectable when on the lower fan mode (from what I see there is only two settings, low and high). When on high the rattle for the most part is gone.
Can you guys put your ear close to the 200mm fans when on low fan settings to see if you get any rattling noises please? Just wondering if I got unlucky or this is how they all are due to it being so cheap.
But yeah, apart from that, very good case for the money!
I do like RGB myself, could not give a toss what others think. I do go through phases though, as I also like the plain look also. ARGB is more fun though, can ways just turn it off when you get the girls round I suppose? The remote makes it easy to do. LolThose magnetic strips look. Like a great finishing touch. I never thought I'd be one for windowed cases and RGB but I can't wait to pimp up my pcs![]()
Static pictures do not do it justice though, looks much better in person and build quality is very good. Cooling is very good also. Just wish the fans would not bloody rattle!
Not finished tidying up my cables yet by the way![]()
I have no idea to be honest. Not looked yet.Really nice. I'm jealous of your psu shroud.
Those front fans are pwm or dc?
Thanks.
We can see they saved some moneys on the motherboard tray, looks a little bit cheap and no rubber grommets, but really nice case and price.![]()
The glass front does look great hopefully it doesn't hurt airflow too much.
