- 18 May 2010
Yes, worked both with push pins or mounting with rad screws
Great thanks, will look into them. Would be nice if they support motherboard connections like MSI Mystic Light
no they not. 100led ws2812b and silicone sleeve. check ebay neon ledVery..RGB
Are those strips the Corsair thingy ones?
Hey guys, can you mount a EVGA 2080ti in the vertical mount? the reason i ask is its a 3 PCI slot card.
Got my black case on order![]()
Yes you can, the vertical mount supports SLI, so one 3 slot GPU will be ok.
Hey dude. How did you get the fans mounted on the front?I thought it was worth adding my build to the the thread too. Don't see as many OC11-Airs on this thread.
@1nfern0
Just noticed your airflow is a bit odd isnt it? Your bottom fans are extracting and so are your top and side fans.
Is that intentional?
Amazed at how tidy some of these builds are, particularly impressed with that Corsair RGB wiring Abshenton! The hidden part of my rig is a tangle of wires. Anyway this is my work in progress build. Waiting on some white acrylic paint for the vertical GPU mount and a new 30 series graphics card, preferably with go-faster RGB trimmings![]()
