4000 series sorts out that.Bottleneck is the latency, amd sort that then they will easily be gaming King.
AMD are close enough in gaming to the point it does not matter. And looking at sales figures they are out selling Intel 9th gen massively. But would be nice to see them top the charts with Zen 3.
see I think my 3800x is quite a bit down vs say a 9700/9900k, maybe the 3900x with better memory write speeds (due chiplets) and bigger cache would help?
3800X is about on par with the 3900X. Tuned ram is the way to go for more Zen FPS. See below for what I mean when I say the FPS difference is not worth being concerned about. And that is with a 2080ti at 1080p.
https://www.techspot.com/review/1955-ryzen-3950x-vs-core-i9-9900ks-gaming/
A few issues here. There’s no reason to limit to the 9900ks mem frequency to 3600mhz. That’s an AMD problem that it’s limited to the IF ratio.
9900ks has oc headroom on the core and cache which should be used. Again, not an Intel problem that AMD platform has limited to no head room for a high all core clock without risking degradation.
Most of us who actually know to tune mem are generally in the 63,000+ read, write range and 36ns or below. That matters. A lot. Latency and bandwidth on Intel also scale with core and cache speed. Uncore reduces bandwidth and core impacts both.
It’s actually pretty easy to limit an Intel system if you don’t know what you’re doing. They require more effort to oc and there are more variables to consider and take more time to dial in. Thankfully they’re virtually impossible to degrade on ambient so you can play with them without too much risk.
cringeVelocity Precision Gamer Clock.
I just watched a very disturbing video shared by BuildZoid.
it features benchmarks of a 9900k at 5ghz on water cooling vs a 3800x at 5ghz on LN2. Both system using 3733mhz cl14 memory with tuned timings.
Cinebench looked promising it the 3800x demolishing the 9900k by scoring 575 single core points to the 9900k's 520.
But that's where the wins stopped, despite the big advantage the 3800x has it still lost to the 9900k in games... this should not have happened
This tells me that if all zen 3 has is higher clocks and higher ipc it won't do anything for gaming, we have a bottleneck somewhere else. What that bottleneck is I don't know but Im willing to beat it's the high memory latency on zen 2.
Hopefully AMD has found a way to fix this bottleneck so that the extra clocks and ipc actually improve gaming performance cause on zen 2 it does very little - the 3800x gaming performance from stock to all core 5ghz only improved by 5%
Stock settings are really what matters though as Stock speeds is all you can guarantee from AMD or INMTEl and also most users dont OC or know how to. For me personally 10 FPS difference is not norticeable and to close to call.
Yes but again, shame they didn't start off with a lower latency to begin with, but for whatever reason, they didn't.This has been known, from the latency of the CCX design. It has always been the case. Hopefully as the design matures we keep seeing the improvements that we have so far.
Understandable but maybe they didn't put much thought into targeting gamers at first, that being the reason the first chips had even higher latencies? I don't know really, could be cost evenNot exactly that simple though hey. That's like saying shame we didn't start out with 32 cores, 5Ghz, 64mb L3 cache.
Compromises needed along the road of design hey![]()
A super interesting thread popped up on the amd reddit and can't see people talking about it. some interesting stuff will be revealed Thursday (7th)
https://www.reddit.com/r/Amd/comments/gcmtb1/something_going_down_on_thursday_zen3/
