Yeah I'm good too thanks. Amd aren't quite there yet but if it makes you happy that's all that matter. Stay safe.All good, you?
Rocking a 3700x and all was well till I saw AMD pull an Intel lol
Yep can't argue with that. So now we know, well kind of. What happens from here we will have to wait and see. Perhaps someone should make a name and shame /motherboard compatibility thread on this forum. Get it stickied and continuously link it in any cpu related thread.
Let's take it out the hands on Amd/Motherboard makers until it has been clarified to a sufficient level.
What does this mean for 300/400 series motherboard users
Users of older Ryzen motherboards will likely have BIOS support for AMD's Ryzen 3000 series of Zen 2 processors, offering up to a 2x increase in core count, higher clock speeds and increased power efficiency. Zen 2 already offers users of older AM4 motherboards a great upgrade option, but sadly, AMD is no longer guaranteeing support for future Zen series Ryzen processors on its older chipsets.
With B550, AMD has also cut-off support for Zen processors that are older than Zen 2, which means that AMD's Ryzen 1000/2000 series CPUs and 2000/3000 series APUs will not be supported on B550. This will allow motherboard manufacturers to keep chipset pricing low and ensure support for future generations of Ryzen processors on AM4. With B550, and has given us a clear cut-off point for socket AM4's CPU support. With X570, AMD made a similar move by removing support for AMD's original Ryzen 1000 series processors.
If 300 series motherboards can support Zen 2, why can't 400 series chipsets support Zen 3?
This remains an unanswered question. The chart below shows that 300-series motherboards don't support Ryzen 3rd Generation Zen 2 processors, but that is not the case. At this time it is unclear whether or not AMD is completely cutting off Zen 3 support for older motherboards or simply not guaranteeing it.
In the future, we hope that AMD and motherboard manufacturers will clarify things further. Some motherboards simply won't have the BIOS space to support a new generation of Ryzen series processors, but that doesn't mean that this is impossible for all older AM4 motherboards. Regardless, owners of 300-series and 400-series AM4 motherboards should not expect to receive BIOS updates with Zen 3 CPU support. If you want forwards compatibility, you will need to be using a 500-series AM4 motherboard.
According to Asrock - 256Mb AMI UEFI Legal BIOS with GUI support. So it would seem I'm ok so I'll just wait until the 4000 series is out and decide if it's something that interests me hence why I brought a 3600 and not something better. If I can't I'll be disappointed but I'll get over it. Can always drop in a 3700 or higher If I need it.TBH,I don't understand all the cloak and daggers style PR on their part. They have good products now,and will have even better ones over the next 12 months,in both CPU and GPU,so they just need to be forthright about things. Also Gigabyte is not going to be happy about any list.....many of their own X570 motherboards have 16MB BIOSes. Here is the list if you want to check your own motherboard:
https://www.reddit.com/r/Amd/comments/c1dnu3/x570x470x370b450b350a320_am4socket_motherboards/
v1201 (Bristol Ridge, Zen): 7.0 MB
v4207 (Bristol Ridge, Zen, Zen+): 9.5 MB
v5220 (Bristol Ridge, Zen, Zen+, Zen2): 11.8 MB
https://www.asrock.com/mb/amd/x570 taichi/#Specification
Those that brought Gigabyte or the like should really take it up with them or possibly avoid in the future.
@CAT-THE-FIFTH
Don't let the fanboys grind you down (little fleckers lol).
When it comes to designed obsolescence they are all guilty of it.
I was an Intel guy until mid 2019, and I'm under no illusions that AMD are saints. (it's all about the £££).
But they are currently offering the best technical advances between generations at the lowest price price points, so that's where I am.
Brand loyalty or arguments defending one over the other is just an waste of time imho.
About as real as it gets.@CAT-THE-FIFTH
Don't let the fanboys grind you down (little theckers lol).
When it comes to designed obsolescence they are all guilty of it. That goes for everybody not just the Pc enthusiasts.
I was an Intel guy until mid 2019, and I'm under no illusions that AMD are saints. (it's all about the £££). Bang on.
But they are currently offering the best technical advances between generations at the lowest price price points, so that's where I am. Same again
AMD Does An Intel, Axes Zen 3 on 400-Series Motherboards, Our Thoughts
Updates: AMD has refrained from commenting and therefore addressing any of our questions at this point, but we have had some interesting conversations with a few of their partners. Again to be perfectly clear on this point, board partners cannot support Ryzen 4000 series processors on 400-series motherboards without AMD’s help, it’s simply not possible. So don’t expect an AIB to crack the code and open up support, again without AMD’s support it’s not going to happen. It does seem as though this was a recent decision by AMD and their partners found out the same time we did, so that’s truly bizarre, but then given the last few product releases from AMD it’s getting harder and harder to be suprised by this stuff.
I’ve also had industry contacts confirm that the AMD BIOS excuse is rubbish and that simple workarounds are possible, just like the one I discussed. In one example there would be a single large BIOS file that you download, then upon flashing you select the CPU series you want to support and it flashes the appropriate code. So at this point it’s now up to the rest of the community to pressure AMD into changing this decision and to open up support for 400-series boards. You guys had better believe that if you give them an inch, they’ll take a mile and we’ll be back to where we were just a few years ago.
Has that not already been posted?
Yes indeed. This is in fact looking like planned obsolescence or lack of a plan obsolescence. This is not good and yes upon review I would certainly be very annoyed if I had brought a 400 series motherboard. Not good.This is getting weirder and weirder by the second.
Possibly but they should just say that not give ulterior reasons.Couple it be that Zen 3 will be PCI-E 4 ONLY hence why the 400 series boards wont have the support for the next gen CPU's.
They need to fix this and quickly.
It certainly seems like it. Who is making these decisions? It's amateur at best if this is all true.AMD really puts it's foot in it at times.
