Yea but Panos says that is not possibleAt nearly 3x the transistor density the 3000 series will be a massive leap forwards over Turing.
https://www.anandtech.com/show/15801/nvidia-announces-ampere-architecture-and-a100-products
The GA100 has 8192 shaders,but the A100 has 6192 shaders and a 400W TDP,which is an increase over the previous 12NM V100 which was 5120 shaders and a 300W~350W TDP. The GPU is huge at 826MM2. Poor yields a problem??
Man, that is not enough RAM ffs. They need to be going 12 for 3070 and 3080, 16 for 3080Ti and 24 for Titan.
The DGX-A100 system being priced at $199,000 compared to $399,000 for previous gen could be a slight glimmer of hope for the pricing of the gaming cards that's a pretty drastic reduction in price.
Que?Apparently the RAM gets restricted as there are somepsome applications that could make use of the RAM. Without sufficient RAM users have to buy the expensive professional cards.
Que?![]()
It already is in cars right now. The latest Mercedes A-Class has nvidia powering the dual panel display and augmented reality.
https://blogs.nvidia.com/blog/2018/02/02/mercedes-benz-a-class-mbux-ai-graphics/
I'm just quoting this to tell you my phone was driving me mad because if I clicked in the middle of the text box to add some words it would sometimes keep duplicating words and stick a letter from the line in the middle of it. Glad it's not just me. Im assuming that's what happened with the somepsomeApparently the RAM gets restricted as there are somepsome applications that could make use of the RAM. Without sufficient RAM users have to buy the expensive professional cards.
$699 for a 3080 and I would bite.
I wouldn't, it would have to be the 3080 ti for that to happen and no I'm not a betting man.
bet your ass the strix version will be about a grand.
new and different shaders/cores.......
I'm just quoting this to tell you my phone was driving me mad because if I clicked in the middle of the text box to add some words it would sometimes keep duplicating words and stick a letter from the line in the middle of it. Glad it's not just me. Im assuming that's what happened with the somepsome![]()
Well i'm glad i didnt go and get all amped like he told me to.
It's there not chat about the GPU making heavy use of texture compression, so the effective ram could potentially be notably higher than the base figure. So 8 GB appearing something closer to 12 etc.
