Glad I could be of assistance guys![]()
Lads, can I get a recommendation or two for a circular saw please? I believe cordless has come on in leaps and bounds in the past few years, so I'd be happy going with battery operated, as it won't need to go for 8 hours a day or anything. However, I would like something beefy enough to be able to cut the likes of solid wood counter-tops as well as the usually ripping of sheet materials etc. And despite being a righty, I prefer having the blade on the left of the unit.
Also, can I get a recommendation for router bit brands? I'd rather pay for 2-3 good bits now, rather than buy a huge kit where the individual quality isn't the best!
Id get a track saw. Brand would depend on budget but having a track saw makes so many jobs way better.
For something like a circular saw I’d get a corded one. For the amount you use it vs the increased cost it makes little sense to go cordless.
All the big brands are unsurprisingly very similar (dewalt Makita etc), but others like evolution offer good value. There are loads of roundups on youtube.
I think what the above person is referring to is a plunge saw. They are more flexible than a circular saw, but you also need to use them with a track and they cost a lot more too. Again all the big brands are fine again but some of the cheaper brands are pretty cheap and you can run into incompatibility issues with the tracks between certain brands, best to stick with the same brand saw and track. Again there are loads of roundups on YouTube.
As above go for a corded track/plunge saw. Very handy for long straight cuts plus being corded it will have the power to cut through some really think timber, I've used mine on railway sleepers.
I have had that model for a good few years now.
Its sturdy enough for the project you have in mind.
anyone ever used a wall chaser and able to give me some pointers. Have borrowed a friends and need to use it this weekend.
Yeah but the workbench will be useful for other things, and paired with a jigsaw (below), should be plenty for Raymond's needs. Even then, it won't hurt to learn to saw with a handsaw, if you're taking on a huge project or are a pro then obviously the power tools are worth it, but for the bonsai tree potting bench, the hand sawing required is not exactly the end of the world.Cutting wood by hand is for people with way too much time on their hands. Get the mitre saw over one of those. Evolution do a proper stand for the saw if you want to go all out.
