Caporegime
- 20 Oct 2002
- Wish i was in a Ramen Shop Counter
Yeah but the workbench will be useful for other things, and paired with a jigsaw (below), should be plenty for Raymond's needs. Even then, it won't hurt to learn to saw with a handsaw, if you're taking on a huge project or are a pro then obviously the power tools are worth it, but for the bonsai tree potting bench, the hand sawing required is not exactly the end of the world.
https://www.wickes.co.uk/Bosch-PST-...KajNn7bHg_0PYFBHexUaAtNMEALw_wcB&gclsrc=aw.ds
The mitre saw seems a bit overkill
I suspect down the line I will have both, I could buy both now today. It's not so much about the cost as these things will lasts and I have no problem spending money on quality products that lasts.
I still have an entire house to renovate so everything I buy will be used down the line I expect. I have now ordered the wood, which has a 2 weeks wait for delivery, so I will sleep on it between now and then and see what power tools I get or not...
I have worked out that I will need to make 36 cuts in total for the table, most of that being the decking planks.
36 cuts by hand or 36 cuts by mitre saw.....
