I'm gonna make a wild guess.
Drop you trrdl to 8, should be fine stability wise, and see if that fixes it.
These are good times, but im not blown away. Are you on 2*16?
i have a 4*8gb configuration
lol. just noticed your TRC is wild. Should be tRP + tRAS. So 50 in your case. apols, I should have picked up on that earlier.i have a 4*8gb configuration
I think that is about right now without moving to 14-14-14 or upping your speed.headed into the bios and set trc to 50 as xmp and you suggested, all was good, re ran MEMbench at default again, it defiantly getting better, tbh i'd be fine where it is now in all honesty
Have you got it set at XMP and then just changed those handful of timings?
yeap set xmp and then headed into dram control and altered tRC, tRFC and finally tFAW to the values in my latest run, all good, Thanks to @Inoton![]()
I'm over 35 seconds faster. With cl16. Although I run 3733.
I've realised the dram calculator is basically a bit rubbish. Glorified spreadsheet.
here is my aida64 ram benchmark
As I wrote above, I would try to use the primary and secondary timings from the calculator as they will be slightly tighter than what is essentially the default timings your running.
It may need a tick or two more voltage. I'm at 1.47v for reference.
but would i notice any difference in real world tasks ie:gaming and benchmarking?
