Cheers for the reply, I’ll stick to Netflix and prime for now. I’ll get it done when lockdown eases.Nope new LNB needs to be fitted too, you mention another box if that's the case the technician will change both boxes and the "main" box will be with the 4k tv. The other box will then be a mini box as the mini is 1080p only.
To be frank UHD on sky doesn't really give any wow factor above 1080p due to its output with no HDR and only 8bit colour. Netflix or Amazon blow it out of the water.
 only got it end of last year. hard disk does make a small noise(even when not downloading anything and on standby) but i thought that was normal, and the sound is amplified because it is sitting on a wooden TV unit.
