- 21 Oct 2011
- ST4
Thinking of branching out your channel and becoming a camwhore?
Ahem... "Personal pleasure device tester and reviewer", please.Thinking of branching out your channel and becoming a camwhore?
what mic is that and any good ?I also got a USB Mic.
snip
same goes for gym equipment...try buying a kettle bell now lolThey must be selling millions of usb mics and HD cams right now.
Streaming just got bigger.
It’s the HyperX quadcast, quality of the device is great, cost me £109.what mic is that and any good ?
wife wants one for her zoom classes she now gives.
thanks
I think mostly the thousands of people working from home or trying to stay in touch with family are putting a strain on stock.They must be selling millions of usb mics and HD cams right now.
need to do some research then.It’s the HyperX quadcast, quality of the device is great, cost me £109.
Audio quality isn’t the best you can buy but it’ll do for streaming or chatting on Discord etc.![]()
Yeah, took me 6 weeks to find the HyperX in stock!I think mostly the thousands of people working from home or trying to stay in touch with family are putting a strain on stock.
It’s the easiest solution, USB straight into the computer.need to do some research then.
she gives music lessons so mic needs to be good to pick music up
Been a while since I got any American soda.
@AndyCr15 probably purchased them all that will be why.
Do some proper research, there are different types of mics and they suit different applications ( for a quick guide https://www.musicianonamission.com/types-of-microphones/ ), for music you won't want to be using a conventional podcast type mic, they are built to pick up voice better than instruments. I'd suggest spending proper money and not buying the cheaper options of streamer/podcast mics...but do your own research of course.need to do some research then.
