Thinking of branching out your channel and becoming a camwhore?
what mic is that and any good ?
wife wants one for her zoom classes she now gives.
thanks
It’s the HyperX quadcast, quality of the device is great, cost me £109.
Audio quality isn’t the best you can buy but it’ll do for streaming or chatting on Discord etc. :)
need to do some research then.
she gives music lessons so mic needs to be good to pick music up
It’s the easiest solution, USB straight into the computer.
You can go for a studio mic but they are XLR connection so you have to go down the route of a DAC etc.
Have a look at the Blue yeti mic, gets great reviews. :)
Do some proper research, there are different types of mics and they suit different applications ( for a quick guide https://www.musicianonamission.com/types-of-microphones/ ), for music you won't want to be using a conventional podcast type mic, they are built to pick up voice better than instruments. I'd suggest spending proper money and not buying the cheaper options of streamer/podcast mics...but do your own research of course.
