Yeah, they could bump clocks to 5.5ghz and call it lava lake.I cant help but think if this refresh had been from intel it would have been a "new generation" on a new socket![]()
The ryzen 4000's are expected to be announced end of september so thats 3 months after this would launch. Wouldn't it just be better to wait and weight the options for price performance since the 3000 series and these would probably get a price cut to be competitive with the new products.
Seems a bit odd having a gpu naming convention attached to CPU's, "xt". Still i suppose it differentiates them from the previous iterations.
Was considering a 3900x, might snag the xt if its a decent little bump up, and assuming its x370 compatible.![]()
AMD love using "X" in their naming schemes. You could pair a 3900XT with a XFX RX 5700XT and an X570 motherboard![]()
I wouldn't bet against early 2021. With any 2020 release being server parts or whatever.Quite bizarre timing to release but maybe Zen 3 won't be until end of 2020 / early 2021?
LOLShould name them
3600 Super
3800 Super
3900 Super
I'll be shocked if these run at ~5Ghz.... which they would need if they are to gain anything worthwhile over existing Zen 2 CPU's.
N7P gives 7-10% higher clock speeds on same power envelop. So 4.9-5Ghz is easily possible
