- 18 May 2010
- London
Which over priced GPU are you thinking of upgrading to ?![]()
3070 or 3080
Thought you meant you wanted to buy a GPU upgrade today3070 or 3080
Just change a few settingsStarting to feel like I need a GPU upgrade. Turned on fps overlay today in BFV to see how low fps actually are.
Around 70 ish average up to 100 and as low as around 45. (at 1440p)
Lol. DP = Double Precision dude.
SP was the internal pricing policy for Pascal, and DP was used for Turing. Let us hope there is not a TP for the early adopter Bunghole.
Good one. It's still listed on Nvidias website
Hmm.. You seem to have confused the P for precision with penetration...![]()
Thanks for the update!The 2080 and 2070 are discontinued and have been replaced by the 2080 Super and 2070 Super.
Apparently so.Thanks for clarifying, some of us here thought it was double penetration
It depends on the eyes that do the watching. I'm not forgetting anything, I'm just not so easily blinded by fancy names, half baked features and absurd price tags. A 104 chip is not, in my book, a high-end chip, that is reserved for the 102 and above. You are of course free to believe otherwise.The Die size tells the real story and it's a high end die size. And aren't you forgetting it's an RTX, not a GTX card?
Internal die names do not always indicate the tier of the chip. Since Fermi there have been changes every generation. And if you do go by Nvidia's current standards, then the GA106 will not be low end cards. The chip will used in the mid to high end cards in the $350 to $550 price range. The GA116 would be the mainstream cards covering the $249 to $350 range.
This:I sold my Titan Pascals a day or two after 1080ti announcement and only lost £120 each which was lucky ( buyer hadn't seen 1080ti news but a couple had and tried to strongarm me into dropping price) but I'd wouldn't buy Titans again unless swimming in cash.sell your card in the couple of weeks before hard launch of next series. I've never done it but am intrigued to try it this round. That said not really sure what i'm buying more GPU power FOR.
Sure new consoles will in time trickle down and push PC hardware, but I think that will be 12-18 months down the line. At that point an Ampere refresh will be out.
You can't 'win'. Pay to play comes to mind
Well, it seems to me that the difference in opinion between what you think and what I think is simply that you look at the price where I look at the die's available. Just because Nvidia likes to pull a 680 once in a while doesn't make it a proper high-end card in my opinion.
die names dictate the tier of the chip and a GA106 die by Nvidia's current standards dictates a lower-end chip.
Holy...
Say what you like about Nvidia, but they are true innovators in their field(s).
Can you please explain why "it will take years, if ever" to see any in-game implementation?Meh, a tech demo that will likely take years if ever to see any in-game implementation at decent frame rates.
Of course it was a tech demo, you are stating the obvious. However if they have found a way to dramatically improve RT lighting then why would it take years to implement or why would it never appear? It was first announced 3 years ago so I doubt it is now so away from being able to be implemented, especially when Ampere with it's vastly increased RT prowess is released https://research.nvidia.com/publication/2017-07_Spatiotemporal-Variance-Guided-Filtering:Because its a tech demo, it's showing off a scenario specifically designed to show off some effects, it's not representative of a real game so frame-rate isn't an issue for them as all the processing power is put into powering the demo. Games have much more going on than just some visual effects so the same processing power in a game vs a tech demo likely isn't present as other assets are also making use of it.
