Hey guys,
I have decided to do a transplant for my setup to a new case..
I am going to order (from OCUK) a Phanteks Eclipse P400A case, and wondering what you would do regarding cooling setup..
I have a 240mm AIO on order, and was thinking of the following for my cooling setup..
3x120mm fans in the front, the 240mm radiator on the top two front fans, leaving the bottom one open to help airflow to the bottom / PSU area..
Two extraction fans in the top, and a 120mm fan in the back, also extraction..
Does that sound reasonable? Will the 240mm look silly with the bottom fan exposed? Or am I just being anal?
Also, my choice for the front rad setup, is from YouTube, I have seen a big difference in temps from a front install against a top rad setup.
Cheers guys!
Cheers guys!
