- 19 Dec 2017
Let's be honest, they are rare and preventative maintenance for that issue costs about the same as the chap above was quoted for a years warranty!
And this (as I had it explained by some BMW Warranty bod over the phone Last year to me) is how the warranty makes them a profit, the higher claims on say a 3 series are more than offset by the premiums paid (usually as a box tick) by a 7er owner.....Exactl
It drives me insane.
A 520d and a 320d are, for repair purposes, essentially the same car. But because it's priced by series not by model you'll pay significantly more for a manual 520d with no navigation than you will for a fully loaded 440i M Sport with folding metal hard top roof
It completely writes off the 7 series for me as it's twice the price of a 5 series despite having the same engine, gearbox, electronics system, etc etc
It's almost as if aging M cars are a bit sensitive!
I'd set fire to my car after all that, too.
E6x M5 is one of the bravest of brave pills, but it's the exception rather than the rule.
The irony being if you have a warranty I'm not sure you'd be able to get the work done outside the main dealer network (extended warranty that is).TBF, he says in his comments that 90% of his issues came about from poor work being carried out at the dealership which needed rectifying time after time.
If you drive this into a dealer these days with an issue, there is likely to be no one working there who has ever done proper in depth work on these. They only put this engine in the M5 and M6 both of which are not common cars at all and the most anyone in a dealership workshop is likely to have done on one is given it a service.
If you roll in with some sort of engine malfunction, you're going to get someone who doesn't have a clue what they're doing trying random things and ultimately probably causing more issues than their solving. These are the sorts of cars which should be taken to specialists only.
Couple of questions regarding the BMW extended warranty.
My mate is looking at buying a used M235i from a private seller and is thinking of taking out the extended warranty for at least the 1st year to cover his back incase there are any issues.
I presume all he needs to do once he buys the car is go online and purchase the extended warranty? Or are there any pre checks that BMW need to carry out first?
Is it only servicing that you need to use the dealers for, and you're ok to use for own garage/specialist for non warranty work?
Is there an initial period where you can't make a claim, or how does it work regarding if a fault is determined to be pre existing or not?
The car he's looking at is a 2014 model with full BMW service history, he's just trying to go into it with his eyes wide open and determine if the warranty is worth the cost (~£1k as the mileage is round 70k)
Is it just me or are we noticing a lot more Tesla’s around compared to bmw m cars, saw maybe 2 m cars and about 10 Tesla’s yesterday including 2 of the model, x, just general motorway in the north west.
I've run a few registrations through it and been declined in the past
