I've got a spare XP-M, but it's only a 1500+ (will still likely clock it's knackers off though!)
Such great chips, board has a 2600 in it.
2600+ XP or XP-M and is it a T'bred or a Barton?
Looks identical to my NoS Dell GeForce 2 PRO.Just won this
https://www.ebay.co.uk/itm/NVIDIA-0378TX-180-P0020-0100-E02-Video-Card-/333623665124?nma=true&si=EhpCy6Rdq97gRlvp%2FI%2BpRhOOi3U%3D&orig_cvip=true&nordt=true&rt=nc&_trksid=p2047675.l2557
Didn't expect to win it at that price. Dell Geforce 2 GTS?
Either way, decent card for the money.Based on those images, probably a GF2 Pro thenEither way, decent card for the money.
@paradigm - Regarding the iffy 3dfx V3 I sent you, I think at this point I'm quite happy to just let you keep it if you're happy with that. Based on what you've done already, it's probably going to be a faff to fix (if it even can be). Perhaps you could use it for parts down the line?
Completely up to you mate, if you want it back then I'm happy to send it, it's yours afterall! If not then yes I'd keep it as parts for any other Voodoo 3's that are poorly!
ThanksYeah you keep it, you put some effort into fixing it (plus the cost of a few replacement caps) so think it's only fair. I got lucky recently with that 'faulty' V2, so I have a card I can use for Glide-based stuff now. Thanks for taking a look though!
. That’s very kind of you and appreciated! Just go straight to Farnell, RS or DigiKey.Whats the best place to buy good quality genuine caps etc, want to avoid the junk.
Preferably you want Nichicon, Rubycon or Panasonic.
